When I attempt to install a module I just built into ROS, it fails to 'find' a required package because of an error in the associated check_deps.py file. The dependency it is trying to find is package genmsg, which is in fact installed (I even reinstalled, just in case). The Python file genmsg_check_deps.py is producing a Python error very early, during start-up, at the line: from genmsg import EXT_MSG, EXT_SRV, MsgContext claiming that there is no module named genmsg.
But of course this Python file itself is in lib/genmsg
We are using ROS Jade
Originally posted by sarima on ROS Answers with karma: 16 on 2016-03-07
Comment by jackie on 2016-03-07:
Did you include genmsg in your package.xml as a build_depend?
