I'm trying to analyse the Algorithms in SelfLocalizer node which is Particle Filter, Beam range finder, and Field range finder model. I understand the theory behind it but I want to see what is coming out in some of the equations.
I have tried to add std::cout << "TEST" << std::endl;
, printf ("%s \n", "TEST");
and ROS_INFO("usage: add_two_ints_client X Y");
in the code, then make the project and then run one of the launch file. I can see a lot of messages and parameters are printet in Terminal, but not the the one that I was expecting. Can anyone help me with that, or how can I read the value of a specific equation ?
Originally posted by RosUser on ROS Answers with karma: 81 on 2016-03-03
