Dear reader,
While installing indigo on a fresh debian weezy install on the BeagleBone Black. I came across an error. In step 2.2.1 from this guide.
While doing the latest command for libconsole-bridge-dev: "sudo checkinstall make install"
I first change the name, as stated in the guide and then when pressing enter I get this.
Installing with make install...
========================= Installation results =========================== [100%] Building CXX object CMakeFiles/console_bridge.dir/src/console.cpp.o cc1plus: error: unrecognized command line option ‘-std=c++11’ make[2]: *** [CMakeFiles/console_bridge.dir/src/console.cpp.o] Error 1 make[1]: *** [CMakeFiles/console_bridge.dir/all] Error 2 make: *** [all] Error 2
**** Installation failed. Aborting package creation.
Cleaning up...OK
Bye.
Does anyone know what I should do first in order to overcome this error.
More info:
gcc version 4.6.3 (Debian 4.6.3-14)
kernel version: 3.8.13-bone79
Thanks for the help
Kenavera
Originally posted by Kenavera on ROS Answers with karma: 56 on 2016-01-10
It turns out that my gcc version 4.6.3 has no support for C++ 11. Therefore it wouldn't compile.
I updated it to gcc 4.7 with this guide and that fixed my problems.
Originally posted by Kenavera with karma: 56 on 2016-01-10
