Hello, I wanted to perform RGBD SLAM with kinect what are the packages that are available for ROS-INDIGO?
Thank you
Originally posted by kaygudo on ROS Answers with karma: 11 on 2015-12-25
Thank you
RGBDSLAM V2 is available and works well. There is a decent amount of explanation and instructions here: http://felixendres.github.io/rgbdslam_v2/
The documentation lists it as using openni_launch, but it works with freenect_launch as well.
One note about installing RGBDSLAM V2 is that you may experience an error during compiling due to SiftGPU, such as *** [build/CuTexImage.o] Error 1
. If this happens, you can adjust the CMakeLists.txt file to turn off SiftGPU by changing the line set(USE_SIFT_GPU 1)
to set(USE_SIFT_GPU 0)
Hopefully this can get you started.
Originally posted by Steven_Daniluk with karma: 606 on 2015-12-25
Comment by kaygudo on 2015-12-26:
But it says it is for ros groovy . will it also work for indigo?
Comment by Steven_Daniluk on 2015-12-26:
Sorry, I didn't explicitly state that it works for Indigo. Some of the documentation is outdated, but if you look on the GitHub link there will be a branch for Indigo, which is fully functional.
Comment by kaygudo on 2015-12-27:
thank you for your help. i git cloned the package to my workspace , but while executing "rosdep install rgbdslam_v2"
i get following error:
ERROR: ERROR: Rosdep cannot find all required resources to answer your query
Missing resource rgbdslam_v2
ROS path [0]=/opt/ros/indigo/share/ros
Comment by Steven_Daniluk on 2015-12-27:
Two things to mention here,
rgbdslam
, not rgbdslam_v2
. If you look in the launch files thats how it is referred to. So try running rosdep install rgbdslam
.Comment by kaygudo on 2015-12-28:
yes thank you, you were right the problem was with my catkin workspace :)
