To be able to do SLAM using the Kinect sensor do I need to convert the point cloud to something simulating a laser scan? I notice that there is a package called pointcloud_to_laser. Are there any examples available showing how to do this?
Originally posted by JediHamster on ROS Answers with karma: 995 on 2011-03-11
There's a tutorial that explains how to do laser-based SLAM with a Kinect-equipped Create. It should be easy to adjust the details to your setup.
Originally posted by Brian Gerkey with karma: 2916 on 2011-03-11
Comment by mmwise on 2011-03-11:
you could buy a DB25 connector and solder this gyro to it http://www.sparkfun.com/products/9059... connect the rate out to the analog pin and you can run that demo... :)
Comment by Pi Robot on 2011-03-11:
I have an iRobot Create and to my knowledge, it does not have an IMU. Consequently, I purchased one of these (http://www.sparkfun.com/products/9623) since there is an existing ROS package (http://www.ros.org/wiki/imu_9drazor) to support it. However, I have not yet tried it as it requires a firmware upgrade to the IMU which I have not yet had time to do.
Comment by JediHamster on 2011-03-11:
Just out of curiosity, does the iRobot Create have an IMU ?
Depending on your needs, you could also use RGBD-6D-SLAM.
Originally posted by Felix Endres with karma: 6468 on 2011-03-11
Comment by Felix Endres on 2011-03-12:
6D-SLAM could be overkill then. It's difficult to find good features based on depth structure, though. Most are hardly as descriptive as visual features.
This is also another more general approach which I could use, although the full 6D motion is not so critical for a differential drive robot moving on flat floors, and the SURF features could be replaced by features originating from depth structure for greater resilience to blur or low contrast.
