which broken packages are being considered by the system ? Help me to solve this.
neel
sudo apt-get install ros-indigo-desktop-full
Reading package lists... Done
Building dependency tree Reading state information...
Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation: The following packages have unmet dependencies: ros-indigo-desktop-full : Depends: ros-indigo-simulators but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Originally posted by Neel on ROS Answers with karma: 1 on 2015-12-19
Comment by luketheduke on 2015-12-19:
Thanks 130s for formatting the code
