I want to use iRobot create with Gazebo . But its packages are for hydro: http://answers.ros.org/question/127466/how-to-use-irobot-create-in-gazebo-with-ros-hydro/
I could not find for indigo even for hydro too. when I enter
sudo apt-get install ros-hydro-turtlebot It gives this. and same for indigo Reading package lists... Done Building dependency tree
Reading state information... Done E: Unable to locate package ros-hydro-turtlebot
Originally posted by tonyParker on ROS Answers with karma: 377 on 2014-08-30
You need to install the indigo version using sudo apt-get install ros-indigo-turtlebot
Originally posted by tonybaltovski with karma: 2549 on 2014-08-30
Comment by tonyParker on 2014-08-30:
When I try, I get this answer: "E: Unable to locate package ros-indigo-turtlebot"
Comment by tonybaltovski on 2014-08-30:
My apologies, there is no deb for that package yet according to the build farm. However, you can install it from source from Github
thanks one last question, I found most of the packages for hydro, should I revert to hydro ?
Check if you can install the packages you want from source. They should eventually be released to the debs.
