Quadcopter frames seem to consistently follow the same X design. For example:
Quadcopter X Frame
I'm curious to know why that is. It certainly seems like the most efficient way to use space but is it the only frame design that would work for quadcopters?
For instance, would a design like this work?
Quadcopter O Frame
Why or why not?
  • $\begingroup$ That would still work, yes. As long as the propellers are in the right position. $\endgroup$
    – wafflecat
    Apr 11, 2015 at 6:41
  • $\begingroup$ mechanical inconvenient. $\endgroup$
    – lanyusea
    Apr 12, 2015 at 8:18
  • $\begingroup$ camera ships especially follow that shape to give a central mount point to balance the heavy weight without having to correct for inertia of a heavy item on one side. However, racing quads tend to use the H config more, with a central rail. That design allows for better weight distribution with an FPV cam up front. $\endgroup$ Apr 17, 2015 at 6:50
  • $\begingroup$ five people bothered to answer this, even though only 2 thought this was a decent question? $\endgroup$
    – Octopus
    May 29, 2015 at 22:35
5 Answers 5
A frame in that configuration or any other witch holds the props in a square without being unbalanced would work, the reason that most people do it with cross bars is because the FC batteries and ESCs must go somewhere. For your proposed solution you would have to balance all of that equipment around the ring running power and control lines all around possible causing interference and inefficiencies. Not to say it doesn't or couldn't work, but it will not be ideal.
  • $\begingroup$ The PIDs would compensate for any unbalance... $\endgroup$
    – dm76
    Apr 12, 2015 at 6:32
  • $\begingroup$ They would up to a point, if say one side is 2x times as heavy as the other side then the props on one side would need to run twice as fast giving you less maneuvering overhead and possibly difficulty moving in one direction. but if it was all mostly balanced and you had everything setup properly there is no reason why it would not work. $\endgroup$
    – Mark Omo
    Apr 12, 2015 at 14:47
To answer your questions directly, the X-shape is not the only design that will work. There are many variations of frame design around a number of rotors that can range from 3 to (in some cases) 8.
enter image description here
Since it hasn't been mentioned in the other answers, I want to point out that perhaps the biggest reason for the X shape is to keep the weight in the center, which decreases the moment of inertia of the vehicle -- the vehicle will pitch and roll more easily in response to the thrust.
5
  • $\begingroup$ +1 for reduces moment of inertia. I don't think enough people understand it or its impact on performance. Lower moments of inertia give faster accelerations for the same torque, so twisting motions (like you would use to stabilize or position the craft) become more responsive. $\endgroup$
    – Chuck
    May 29, 2015 at 12:40
  • $\begingroup$ I wanted to add that a decreased moment of inertia means less power expended on maneuvering, but I couldn't find a study that quantified it. $\endgroup$
    – Ian
    May 29, 2015 at 13:06
  • $\begingroup$ You don't need a study; it's supported by physics. Torque required to accelerate is given by $\tau_{accel} = I_{structure} \alpha$, where $\tau_{accel}$ is the torque required to accelerate, $\alpha$ is the acceleration, and $I_{structure}$ is the moment of inertia for the craft. The power expended is given by $P=\tau \omega$, where $\omega$ is the rotational speed. For a given acceleration (implying also a given rotational speed), a lower moment of inertia lowers torque requirements, which in turn lowers the power expended. $\endgroup$
    – Chuck
    May 29, 2015 at 14:19
  • $\begingroup$ Also, a quadcopter doesn't have any means to produce lateral thrust during level operation. It produces lateral thrust by rotating, creating an off-vertical thrust vector. The horizontal component accelerates the craft to a desired speed, at which point the craft rotates again for a vertical thrust. When the target position is near the craft rotates, decelerates, rotates again. All of this happens very quickly, very frequently, much more so than you would change altitude. All of the rotations add up, so anything you could do to reduce the moment of inertia would yield gains on flight time. $\endgroup$
    – Chuck
    May 29, 2015 at 14:23
  • $\begingroup$ Indeed, qualitatively the effect is obvious. But like I said, I was looking for something more quantitative -- showing how sensitive the power usage is to the moment of inertia. It's definitely worth putting the weight in the center, but how much benefit is there to tightly optimizing the center? You can calculate the power usage difference from simple physics, but that won't tell you how much flight time is devoted to pitch and roll actions. $\endgroup$
    – Ian
    May 29, 2015 at 14:33
As it has been said in other answers it would still work any other configurations. But the X is practical for several reasons:
  • having a centre point adding the electronics, battery, etc. These add a lot of weight so it's better to have them in the centre, otherwise your quad will spend a lot of energy trying to remain horizontal.
  • when adding a camera, the frame is not in the field of view.
  • there is something cool about the X... ;-)
Any frame design that:
  • Is not too heavy
  • Does not flex too much
  • keeps the motors the same distance apart when measured diagonally(to use default x or + motor layouts)
  • can fit all required equipment
  • allows the flight controller board to be mounted in the centre
There are many other frame designs like the V-tail or dead cat that require you to use different motor mix settings.
Also you may want to look into H frame designs, they are relatively simple, and easy to repair.
Those two designs you posted are identical as far as the placement of propellers goes, so yes, they would both work, and with exactly the same flight electronics.
The second ring design though, uses approximately twice as much material for the frame hence it will be heavier, while in practice you'd probably want to minimize the weight of the airframe. There doesn't seem to be a convenient place to mount a central flight computer, but I'm sure a little creativity could lead to a ring design that is practical.
Here's a slightly different configuration for a quadcopter (called V-tail) that seems to be gaining popularity. It would need slightly different logic.
