I stumbled upon the not-quite-as-well-documented feature of dynamic_reconfigure groups.
As I understand, whenever you set up a server, it should call the callback and initialize the config parameter with the values found in the cfg file. However, my groups are not being set to defaults, only my "bare" parameters are. If I change one of the group parameters, then the change takes effect.
Is there something I'm missing, or should I file a ticket?
(btw this ticket mentions inconsistent behavior, but it's talking about states rather than defaults, so I'm not sure it's related.)
void dynamic_cb(pkgConfig &config, uint32_t){
a = Duration(config.a);
b1 = config.groups.b.part1;
b2 = config.groups.b.part2;
cfg file:
gen.add("a", double_t, 0, "a_description", 1, 0, 10000)
group = gen.add_group("b")
group.add("part1", double_t, 0, "b1", 3.0, 0.0, 10.0)
group.add("part2", double_t, 0, "b2", 3.0, 0.0, 10.0)
Originally posted by thebyohazard on ROS Answers with karma: 3562 on 2015-07-09
Post score: 4
Comment by ffurrer on 2016-06-07:
any update on this?
