I tried to release a ROS Indigo version of a package, but I got an email back saying that "the build failed in Jenkins". This seems to be the error:
Could not find a package configuration file provided by "Eigen" with any of
the following names:
EigenConfig.cmake
eigen-config.cmake
However, the package's package.xml has both a build and a run dependency on cmake_modules, and the CMakeLists file contains:
find_package(catkin REQUIRED COMPONENTS cmake_modules [...])
find_package(Eigen REQUIRED)
UPDATE
According to the answer below, I've updated the CMakeLists.txt: https://raw.githubusercontent.com/atenpas/handle_detector/indigo/CMakeLists.txt
However, Jenkins is still failing with the same error message as before.
Originally posted by atp on ROS Answers with karma: 529 on 2015-04-25
