I am trying to compile a ros node that uses the eigen library. I am working on Indigo, but I assume that the node was programmed in another version of ROS, since the original programmer does not have this problem.
I get this error:
By not providing "Findeigen.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "eigen", but
CMake did not find one.
Could not find a package configuration file provided by "eigen" with any of
the following names:
eigenConfig.cmake
eigen-config.cmake
Add the installation prefix of "eigen" to CMAKE_PREFIX_PATH or set
"eigen_DIR" to a directory containing one of the above files. If "eigen"
provides a separate development package or SDK, be sure it has been
installed.
The eigen library works on my C++ projects, so I know that it is correctly installed. I just can't get it to work with ROS. I looked around to find a solution and I added:
find_package(cmake_modules REQUIRED)
find_package(eigen REQUIRED)
include_directories(${Eigen_INCLUDE_DIRS})
to the CMakeLists.txt, and
<build_depend>cmake_modules</build_depend>
<run_depend>cmake_modules</run_depend>
to the package.xml. However, it didn't solve the problem. Does anybody have the same problem with eigen? What should I do?
Originally posted by Valerio on ROS Answers with karma: 13 on 2015-07-16
