Hi everyone,
These past days, I'm trying to write an RViz dockable panel following the tutorial here.
My goal is basically to display – for now – an empty panel (the strict minimum, for a beginning).
The problem is that all the tutorial is writing with both rosbuild and Qt4, while I would like to use catkin and Qt5. Each time I'm trying to compile, I keep having this error message :
[ERROR] [1426085794.672184440]: PluginlibFactory: The plugin for class 'plugin_panel/Hi' failed to load. Error: Failed to load library /home/mdufour/catkin_ws_test/devel/lib/libplugin_panel.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /home/mdufour/catkin_ws_test/devel/lib/libplugin_panel.so: undefined symbol: _ZTVN8my_panel11PluginPanelE)
My package directory looks like this :
plugin_panel/
|__ CMakeLists.txt
|__ package.xml
|__ plugin_description.xml
|__ src/
|__ plugin_panel.cpp
All the code is in the .cpp
file, for simplification.
Here's my CMakeLists.txt
cmake_minimum_required(VERSION 2.8.11)
project(plugin_panel)
find_package(Qt4 REQUIRED)
find_package(catkin REQUIRED)
include(${QT_USE_FILE})
add_definitions(${QT_DEFINITIONS})
add_library(${PROJECT_NAME} src/plugin_panel.cpp)
target_link_libraries(${PROJECT_NAME} ${QT_LIBRARIES} ${catkin_LIBRARIES})
This is my .cpp
(very basic!) :
#include <QWidget>
#include <QHBoxLayout>
#include <QLabel>
#include <rviz/panel.h>
namespace my_panel
class PluginPanel: public rviz::Panel
Q_OBJECT
public:
PluginPanel(QWidget* parent = 0):
rviz::Panel(parent)
QHBoxLayout* topic_layout = new QHBoxLayout;
topic_layout->addWidget(new QLabel("Hi!"));
#include <pluginlib/class_list_macros.h>
PLUGINLIB_EXPORT_CLASS(my_panel::PluginPanel, rviz::Panel)
The package.xml
(overloaded for sure) :
<?xml version="1.0"?>
<package>
<name>plugin_panel</name>
<version>0.0.0</version>
<description>
An additional (yet empty) panel in RViz.
</description>
<maintainer email="[email protected]">Matthieu</maintainer>
<license>BSD</license>
<buildtool_depend>catkin</buildtool_depend>
<build_depend>roscpp</build_depend>
<build_depend>roslib</build_depend>
<build_depend>rviz</build_depend>
<build_depend>pluginlib</build_depend>
<build_depend>class_loader</build_depend>
<run_depend>roscpp</run_depend>
<run_depend>roslib</run_depend>
<run_depend>rviz</run_depend>
<run_depend>pluginlib</run_depend>
<run_depend>class_loader</run_depend>
<export>
<rviz plugin="${prefix}/plugin_description.xml"/>
</export>
<package>
And finally the plugin_description.xml
<library path="lib/libplugin_panel">
<class name="plugin_panel/Hi"
type="my_panel::PluginPanel"
base_class_type="rviz::Panel">
<description>
An empty panel.
</description>
</class>
</library>
Phew! Sorry, that was heavy…
I'm certainly missing something in one of those files, but I can't figure out what.
Thanks for your answers.
Originally posted by anonymous21729 on ROS Answers with karma: 15 on 2015-03-11
