[ERROR] [WallTime: 1412925263.358047] Received a goal with velocities that are higher than 2.000000
The error you are seeing is not caused by exceeding a real, actual velocity limit, but rather by a check in ur_driver
that compares the requested velocities against a (private) parameter called max_velocity
. The idea behind the check was most likely to be able to enforce a maximum velocity over a trajectory. This is currently not (very well) documented.
This parameter has a default of 2 rad/s (this is in joint space).
You can do two things:
add a max_velocity
parameter to the ur_driver
node element in ur_bringup/launch/ur_common.launch
, like so:
<node name="ur_driver" pkg="ur_driver" type="driver.py" args="...">
<param name="max_velocity" type="double" value="YOUR_MAX_SPEED" />
</node>
edit ur_driver/src/ur_driver/driver.py
, and increase the default value for the max_velocity
parameter.
For now, I'd recommend you use option 1 on a source checkout of the universal_robot repository. Option 2 is really not a good idea.
I'll open a ticket on the github repository asking for this to be documented better.
Edit: for reference, see universal_robot/issues/124.
Originally posted by gvdhoorn with karma: 86574 on 2014-10-10
