Im currently using Ubuntu and running on ROS groovy.
My intention is to live stream RGB images from Asus Xtion pro and run the houghlines transform algorithm from opencv. I created my own package and ran the code for the openCV houghlines codes and manage to detect lines from images that i put into it.
But how can i combine live stream image from asus with the houghline algorithm? I want to detect a marked out box on the floor using a Asus Xtion Pro and finding the center point of the box.
Can any one help me with this. I just started using ROS and OpenCV and went through the tutorial.
include "opencv2/highgui/highgui.hpp"
include "opencv2/imgproc/imgproc.hpp"
include <iostream>
using namespace cv;
using namespace std;
static void help()
    cout << "\nThis program demonstrates line finding with the Hough transform.\n"
            "Usage:\n"
            "./houghlines <image_name>, Default is Trapezium.jpg\n" << endl;
int main(int argc, char** argv)
    const char* filename = argc >= 2 ? argv[1] : "Trapezium.jpg";
    Mat src = imread(filename, 0);
    if(src.empty())
        help();
        cout << "can not open " << filename << endl;
        return -1;
    Mat dst, cdst;
    Canny(src, dst, 50, 200, 3);
    cvtColor(dst, cdst, COLOR_GRAY2BGR);
    if 0
    vector<Vec2f> lines;
    HoughLines(dst, lines, 1, CV_PI/180, 100, 0, 0 );
    for( size_t i = 0; i < lines.size(); i++ )
        float rho = lines[i][0], theta = lines[i][1];
        Point pt1, pt2;
        double a = cos(theta), b = sin(theta);
        double x0 = a*rho, y0 = b*rho;
        pt1.x = cvRound(x0 + 1000*(-b));
        pt1.y = cvRound(y0 + 1000*(a));
        pt2.x = cvRound(x0 - 1000*(-b));
        pt2.y = cvRound(y0 - 1000*(a));
        line( cdst, pt1, pt2, Scalar(0,0,255), 3, CV_AA);
    else
        vector<Vec4i> lines;
    HoughLinesP(dst, lines, 1, CV_PI/180, 50, 50, 10 );
        Vec4i l = lines[i];
        line( cdst, Point(l[0], l[1]), Point(l[2], l[3]), Scalar(0,0,255), 3, CV_AA);
    endif
    imshow("source", src);
    imshow("detected lines", cdst);
    waitKey();
    return 0;
Originally posted by Azl on ROS Answers with karma: 3 on 2014-08-05
Hi there and welcome to ROS
You should check out the tutorial Writting a simple image subscriber, there you have a clear explanation on how to subscribe to an image topic and transform that to an OpenCV-compatible data structure using cv_bridge.
Then on the image subscriber callback you execute the routine that you implemented to detect HoughLines.
Avoid using cv::imshow and cv::waitKey inside the callback or be really careful using it. If you want to visualise the results I would recommend you to publish the result of your processing (cdst in the code that you posetd) into its own topic and use the package image_view to visualize it.
Then to start the Asus Xtion Pro run the command:
roslaunch openni2_launch openni2.launch
This will publish the topic /camera/rgb/image_raw (among others)
Then run the node that you will implement following the tutorial that I mentioned before, remapping the topic camera/image to /camera/rgb/image_raw.
Originally posted by Martin Peris with karma: 5625 on 2014-08-05
Comment by Azl on 2014-08-05:
Thanks for the prompt reply. Greatly appreciated.
I will start on the tutorial above.
