Hi,
I am following the moveit tutorial to load pr2.urdf.xacro in MoveIt Setup Assistant. As I click on Load Files I get the following symbol lookup error:
[librospack]: error while executing command /opt/ros/hydro/lib/moveit_setup_assistant/moveit_setup_assistant: symbol lookup error: /opt/ros/hydro/lib/libmoveit_setup_assistant_widgets.so: undefined symbol: _ZN3ros7console5printEPNS0_10FilterBaseEPvNS0_6levels5LevelEPKciS7_S7_z
Any suggestions on fixing this ?
Originally posted by adreno on ROS Answers with karma: 253 on 2014-04-18
If you installed MoveIt from source, I would suggest removing the devel and build folders and rebuilding your workspace from scratch.
If you installed from debs, I would update them. There was an issue with a particular release of ros console quite some time ago, which may mean you have outdated debian files.
Originally posted by fergs with karma: 13902 on 2014-04-20
Comment by adreno on 2014-04-24:
Thanks a lot! update did solved the problem :)
Comment by BillyG on 2014-05-02:
Hi. I've did the suggested (debs) update, followed by an install of ros-hydro-moveit-full, but the symbol lookup error is still occurring. Any other suggestions on fixing this?
Comment by dinesh_sl on 2014-05-18:
I also updated the ros installation hand moveit packages but problem remains. Please help.
