When i launch moveit setup assistant i receive the following error.
roslaunch moveit_setup_assistant setup_assistant.launch
... logging to /home/kannan/.ros/log/0d1dacec-30cd-11ec-b94d-e82a44ef4c23/roslaunch-kannan-Lenovo-ideapad-320-15IKB-15791.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
started roslaunch server http://kannan-Lenovo-ideapad-320-15IKB:39523/
SUMMARY
PARAMETERS
 * /rosdistro: melodic
 * /rosversion: 1.14.11
NODES
    moveit_setup_assistant (moveit_setup_assistant/moveit_setup_assistant)
auto-starting new master
process[master]: started with pid [15805]
setting /run_id to 0d1dacec-30cd-11ec-b94d-e82a44ef4c23
process[rosout-1]: started with pid [15816]
started core service [/rosout]
process[moveit_setup_assistant-2]: started with pid [15820]
/opt/ros/melodic/lib/moveit_setup_assistant/moveit_setup_assistant: error while loading shared libraries: libmoveit_kinematics_base.so.1.0.8: cannot open shared object file: No such file or directory
================================================================================REQUIRED process [moveit_setup_assistant-2] has died!
process has died [pid 15820, exit code 127, cmd /opt/ros/melodic/lib/moveit_setup_assistant/moveit_setup_assistant __name:=moveit_setup_assistant __log:=/home/kannan/.ros/log/0d1dacec-30cd-11ec-b94d-e82a44ef4c23/moveit_setup_assistant-2.log].
log file: /home/kannan/.ros/log/0d1dacec-30cd-11ec-b94d-e82a44ef4c23/moveit_setup_assistant-2*.log
Initiating shutdown!
[moveit_setup_assistant-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Originally posted by vidu98 on ROS Answers with karma: 23 on 2021-10-19
Comment by osilva on 2021-10-19:
Can you check the contents of the following directory /opt/ros/melodic/lib/moveit_setup_assistant/ looks you are missing libmoveit_kinematics_base.so.1.0.8 file
Comment by vidu98 on 2021-10-19:
hi @osilva, im missing "libmoveit_kinematics_base.so.1.0.8" like you said,how to install that file.
If you are missing this file, it means moveit is not properly installed. I suggest to check your moveit installation: https://moveit.ros.org/install/
Also do a search of your full drive, it may be installed somewhere else, just to see what happened.
Comment by vidu98 on 2021-10-20:
@osilva i am trying to reinstall moveit, im following "https://moveit.ros.org/install/source/", when i try to run this command "rosdep install -y --from-paths src --ignore-src --rosdistro ${ROS_DISTRO}" i receive following error ; The following packages have unmet dependencies: ros-melodic-ros-controllers-cartesian : Depends: ros-melodic-twist-controller but it is not going to be installed ros-melodic-twist-controller-dbgsym : Depends: ros-melodic-twist-controller (= 0.1.4-1bionic.20210921.212715) but it is not going to be installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution). ERROR: the following rosdeps failed to install apt: command [sudo -H apt-get install -y ros-melodic-pybind11-catkin] failed.
when im trying to run "sudo apt --fix-broken install" i get the following error: Unpacking ros-melodic-twist-controller (0.1.4-1bionic.20210921.212715) ... dpkg: error processing archive /var/cache/apt/archives/ros-melodic-twist-controller_0.1.4-1bionic.20210921.212715_amd64.deb (--unpack): trying to overwrite '/opt/ros/melodic/lib/libtwist_controller.so', which is also in package ros-melodic-cob-twist-controller 0.8.12-1bionic.20210921.230048 Errors were encountered while processing: /var/cache/apt/archives/ros-melodic-twist-controller_0.1.4-1bionic.20210921.212715_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Comment by osilva on 2021-10-20:
Hi I will respond to this question formally and let's start a new question as more people will get the chance to look at it. Thank you.
Comment by gvdhoorn on 2021-10-20:
Don't build MoveIt from source, unless you did that initially to install it.
Just make sure you have no outstanding apt updates for any ROS packages.
I would recommend to undo whatever you did for your from-source install of MoveIt.
The error is pointing to a missing file libmoveit_kinematics_base.so.1.0.8 in the following directory /opt/ros/melodic/lib/moveit_setup_assistant/. To correct check if the file is in the directory, if not then check moveit installation. For more information: https://moveit.ros.org/install/
Originally posted by osilva with karma: 1650 on 2021-10-20
I solved it by using sudo dpkg --remove --force-remove-reinstreq ros-melodic-cob-cartesian-controller-dbgsymto force remove the broken package and then uninstall moveit using sudo apt purge ros-melodic-moveit* and then reinstalled it.
Originally posted by vidu98 with karma: 23 on 2021-11-05
