I'm trying to change the resolution of my Asus Xtion Pro Live. I'm currently running ROS Groovy on Ubuntu 12.04.
I am aware that there is a graphical method to do this, using rosrun rqt_reconfigure rqt_reconfigure
, but is there a command line way of doing this? Or even better, is there some way such that when I use roslaunch openni_launch openni.launch
, the resolution is lowered by default? The default right now is VGA 640x480 @ 30fps. I want to change it to QVGA 320x240 @ 30fps.
I tried adding <arg name="image_node" value="5" />
to my openni.launch file, but it didn't do anything. I set the value to 5 because using the graphical method, QVGA 320x240 @ 30fps is labelled as (5).
Can someone help me out here?
Originally posted by Andrew.A on ROS Answers with karma: 324 on 2014-04-07
