Hi there! I have been cooking in the object recognition kitchen for a bit and so far I succeeded at creating my own models, uploading and training them using TOD.
Unfortunately I can't get the detection to work - i.e. zero poses found. The output looks like this:
***Starting object: 0
5 keypoints in 6 matches
done filling
RANSAC done with 0 inliers
***Starting object: 1
12 keypoints in 51 matches
done filling
***Starting object: 2
2 keypoints in 4 matches
done filling
***Starting object: 3
4 keypoints in 4 matches
done filling
***Starting object: 4
2 keypoints in 2 matches
done filling
***Starting object: 6
6 keypoints in 24 matches
done filling
********************* found 0 poses
Comparing this with the output shown in the tutorial I noticed that I get very few keypoints and matches and RANSAC returns 0 inliers.
Any guess what is going wrong here?
Side note: I'm using Groovy with a source install on Ubuntu Precise 64bit and my sensor is the ASUS Xtion Pro Live.
Update: I can report a tiny success! I switched to the Kinect, activated the high res mode (SXGA for both depth and rgb), captured and trained the new object and I'm getting a found 1 poses now.
5 keypoints in 5 matches
done filling
85 keypoints in 1103 matches
done filling
RANSAC done with 52 inliers
RANSAC done with 5 inliers
Unfortunately, I don't get any (valid) output on the rostopics - markers, poses, recognized_object array are all empty. Is this a bug?
So, my question now turns into this one: Does TOD only work with high res models and input?
Originally posted by bit-pirate on ROS Answers with karma: 2062 on 2013-08-07
Comment by bk on 2013-10-04:
I also was not able get any poses using vga @ 30 fps. bit-pirate: When I used --res sxga and --fps 15 on the object_recognition_capture pkg 'capture' executable, the program locks up. I am using: -a Kinect -set the dynamic reconfiguration(through rqt) to sxga @15fps -using groovy/64bitUbuntu 12.04
Comment by bit-pirate on 2013-10-06:
Hm, hard to say. I haven't been using TOD for a while now, since the reimplemented tabletop object detector is sufficient for my needs. However I did the tests described above with the exact same specs as you. Could you provide more details about where/how the program get's stuck?
Comment by bk on 2013-10-07:
The program hangs at: "Setting sync off". One possible difference is that my depth resolution seems to stay at vga@30fps. Using rqt and dynamic reconfigure, I change the depth resolution to sxga @ 15fps but when I exit out of rqt and enter it again the depth goes back to vga@30fps.
Comment by gautam2410 on 2013-11-26:
I am also getting a similar output. I am using kinect sensor, groovy, 64 bit. Did you find any solution?
Related update, ORK using TOD and tabletop kind of works, I wrote a post with all the steps I followed to get some detections with them: https://groups.google.com/d/msg/object-recognition-kitchen/ijpfJdG9q8E/FPG4HtRBr4AJ
Using ubuntu 12.04, ROS Hydro, last ORK from sources, 32b and 64b tested.
Originally posted by awesomebytes with karma: 66 on 2014-04-15
