Hello,
I am using 2 sick lms100 laser range finders for mapping. I am using Hydro. In my launch file I have both scans being sent to the same topic. The original idea was that I could use gmapping, as someone on this forum said that would work as long as the scans were both published to the same topic. Gmapping would hand;e the transforms. This turned out to be incorrect however, gmapping would only take data from one laser.
The next plan was to convert the laser scans into a point cloud and then send that to octomapping. I can use laser_scan_assembler from the laser_assembler package, but it puts out a service, not a topic. It seems that there used to be a node to republish that data, periodic_snapshotter, but apparently that doesn't work with Hydro. I have found the code and tried to convert it to use pointcloud2, but that didn't work. When I tried to make it with catkin it pulled up a bunch of errors. I also tried to make it with the original file which used pointcloud, but I got the same problems.
So, my question is does anyone have a program that will let me subscribe to a service and republish to a topic, or is there an easier way to do this?
Thanks.
Originally posted by Icehawk101 on ROS Answers with karma: 955 on 2013-12-06
