Hello, I am trying to use the laser_assembler node but have had no luck getting it to work. I am using this tutorial on How to assemble laser scan lines into a composite point cloud. I'm reading in the laser scan data provided by ROS which can be found on the same page as the tutorial.
So far I have moved all of the laser_assembler files into there own folder in my ros_workspace. I have also copied the launch file (found on the tutorial page) and placed it within the "Example" folder within the laser_assembler node, making changes to the package name. I then launch the laser_scan_assembler.launch file along wit the periodic_snapshotter file. I then run rosbag play laser.bag and open up Rviz. I subscribe to the correct topic but nothing shows up in Rviz.
Can anyone help he clarify what I'm doing wrong and point me in the right direction?
Originally posted by tyler258 on ROS Answers with karma: 93 on 2011-09-30
