I am trying a very simple task. I have a 2D laser scanner and 3D velodyne laser on my robot and I want to create an assembled point cloud which includes data from both lasers in one point cloud. I am trying to have laser_assembler package do all the work with laser_scan_assembler and point_cloud2_assembler nodes, which both provide services of same name /assembled_point_cloud which is of the same type sensor_msgs::PointCloud.
The problem I'm facing is that my temp_service_call_node only subscribes to one service (the one provided by point_cloud2_assembler), and gets no data from laser_scan_assembler. Also, if I kill the velodyne node, so that no point cloud2 data is published for point_cloud2_assembler, it doesn't change anything. /assembled_point_cloud which instead of showing only 2D laser scan data when no point cloud2 data is available, keeps subscribing to the point_cloud2_assembler which doesn't give any data.
Is there anything I'm missing or a different approach that I can try?
Please see code for reference-
Here's my launch file:
<launch>
    <node type="laser_scan_assembler" pkg="laser_assembler" name="laser_scan_assembler">
        <remap from="scan" to="/laser/scan"/>
        <remap from="assemble_scans" to="assembled_point_cloud"/>
        <param name="max_scans" type="int" value="1" />
        <param name="fixed_frame" type="string" value="base_link" />
    </node>
    <node type="point_cloud_assembler" pkg="laser_assembler" name="point_cloud_assembler">
        <remap from="cloud" to="/laser/point_cloud"/>
        <param name="max_clouds" type="int" value="1" />
    </node>
     <node type="point_cloud2_assembler" pkg="laser_assembler" name="point_cloud2_assembler">
        <remap from="cloud" to="/laser/point_cloud2"/>
    </node>
</launch>
temp_service_call.cpp file:
void publishPointCloud2()
    //Wait for service to start
    ros::service::waitForService("/assembled_point_cloud");
    ros::Rate r(updateRate);
    while(ros::ok())
        assemblerService.request.begin = assemblerService.request.end;
        assemblerService.request.end   = ros::Time::now();
        if (assemblerClient.call(assemblerService))
            pointCloud = assemblerService.response.cloud;
                    sensor_msgs::convertPointCloudToPointCloud2(pointCloud, pointCloud2);
            ROS_INFO("Got cloud with %u points\n", assemblerService.response.cloud.points.size());
        else
            ROS_ERROR("Service call for getting assembled laser scan failed\n");
        if (pointCloud2.data.size() > 0)
            pointCloud2Publisher.publish(pointCloud2);
        ros::spinOnce();
        r.sleep();
Originally posted by ajain on ROS Answers with karma: 281 on 2014-10-21
ROS does not allow two nodes to provide the same service.
You should instead remap one or both services to a different name, and call them separately.
Originally posted by ahendrix with karma: 47576 on 2014-10-21
Comment by ajain on 2014-10-21:
Okay. So if I subscribe to two different services for point_cloud2 from each assembler and then use pcl::concatenatePointCloud() to merge them, will it take care of assembling point clouds with closest timestamps and returning the merged point cloud with latest timestamp?
Comment by ahendrix on 2014-10-21:
It looks like you're trying to assemble only the most recent scan from each sensor into a composite cloud. Since the primary purpose of the laser assembler is to buffer and assemble multiple scans, it isn't really helping you here.
It may be simpler to subscribe to the topics in question and assemble the scans yourself, using the source code for the laser scan assembler as inspiration.
