I agree this is not really the place, but with that being said, I would strongly recommend you the Xbox360 version, unless you don't want to use ROS.
Some (advanced) modifications have to be made to manage to use windows kinect with ROS.
Moreover, please note there are two models of kinect for Xbox360. The last model can have some drawbacks if you are a very advanced user trying to do multiple kinects on the same computer.
(see this topic if you want to know a bit more about it)
However, for most people, the two models of kinects for 360 are not different, as they are both recognized in ROS.
Have a good day,
Bests regards
Originally posted by Stephane.M with karma: 1304 on 2013-11-08
Comment by Athoesen on 2013-11-13:
Well that sucks... I've been using three 1473's at once without issue in ROSHydro. Hope problems don't come up when I get to more advanced techniques like multiplexing.
Comment by Stephane.M on 2013-11-14:
The problems appear only if you want to use some things, like calling the kinect by serial for example. For most applications, it doesn't change anything (which explains that there is NO documentation for this model...)
Have a good day !
Comment by Athoesen on 2014-01-08:
I just realized this might be my current issue. If it doesn't have a serial number, does that mean that intrinsic calibrations cannot be saved? And moreso, does that mean that I cannot use packages like camera_pose_calibration since they require this? I am trying to combine frames from 3 Kinects.
Comment by Stephane.M on 2014-01-08:
Try to do the intrisic calibrations, and you will see if they are saved or not, and let us know.
Comment by Athoesen on 2014-01-09:
I have one from the 1414 model, and one from both of the 1473's. Both of the 0000.yaml files(rgb and depth) are from the first 1473 I calibrated (Kinect 2). My 3rd Kinect's calibration didn't overwrite either one. Even so, shouldn't camera_pose_calibration just call the 0000.yaml files twice?
Comment by Stephane.M on 2014-01-12:
Yes probably... I am sorry, but right now, I am unsure of what your problem really is. You should open a new thread explaining exactly what works, what doesn't, and what are the outputs (and your config).
Bests regards
