Hey :),
i got some issues using a Kinect for Windows.
I find out that this Kinect is not supported by Openni yet. here and here and this command:
roslaunch openni_launch openni.launch
throws an error like this:
[/openni_node1] No devices connected.... waiting for devices to be connected
I tryed to use the unstable version of openni and ps-engine as mentioned at this question but this sill not works. So the real Question whitch arives. Is there some kind of workaround for this issue?
for advising purposes: The easy solution for this issue was just to take an older Version of Kinect.
Originally posted by paetti88 on ROS Answers with karma: 25 on 2012-11-13
Kinect4Windows can be made to work. The links below must help.
link for kinect 4 windows on ubuntu.........or mitchtech
http://www.20papercups.net/programming/kinect-on-ubuntu-with-openni/
https://groups.google.com/forum/?fromgroups=#!msg/openni-dev/h0F6kYCNigs/BR6iqqFhSJ8J
http://mitchtech.net/ubuntu-kinect-openni-primesense/
If openni does not build then, install openjdk-7-jre and openjdk-7-jdk
after cd SensorKinect type git checkout unstable
openni_camera and openni_launch wont wont in the first go and say that this file "XnCppWrapper.h" is missing. Search for it and move all the contents of that folder to the /usr/include/
Never do rosdep for openni_Camera or openni_launch beacuase the unstable openni packages will be replaced by the stable ones..
Finally you can you roslaunch openni_launch openni.launch to get the new Kinect4Windows to work
Originally posted by sai with karma: 1935 on 2013-05-27
