Trying out run_chroot_local, I get the following error (full log):
$ run_chroot_local precise amd64 /home/rospasta/catkinws prerelease groovy openhrp3
- ubuntu distro: precise
- architecture: amd64
- script: prerelease
- workspace: /home/rospasta/catkinws
- script args: groovy openhrp3
vvvvvvvvvvvvvvvvvvv pbuilder-env.sh vvvvvvvvvvvvvvvvvvvvvv
+ export CCACHE_DIR=/var/cache/pbuilder/ccache
+ CCACHE_DIR=/var/cache/pbuilder/ccache
+ export PATH=/usr/lib/ccache:/home/rospasta/catkinws/devel/bin:/opt/ros/groovy/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
+ PATH=/usr/lib/ccache:/home/rospasta/catkinws/devel/bin:/opt/ros/groovy/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
+ /home/rospasta/catkinws/jenkins_scripts/prerelease groovy openhrp3
File "/home/rospasta/catkinws/jenkins_scripts/prerelease", line 2, in <module>
from test_repositories import *
File "/home/rospasta/catkinws/jenkins_scripts/test_repositories.py", line 6, in <module>
import yaml
ImportError: No module named yaml
I first suspected that python's path wasn't set right, but other modules seem to be previously imported without an issue. Looking at this thread I now feel like looking into pbuilder
but does anyone already have any idea? Thanks.
Originally posted by 130s on ROS Answers with karma: 10937 on 2013-10-14
