Hey,
I'm trying to compile a rospackage, but I throws the following error:
ImportError: No module named rospkg
I checked if it is installed:
sudo apt-get install python-rospkg -> python-rospkg is already the newest version.
dpkg -L python-rospkg -> /usr/lib/python2.7/dist-packages
And if that is in my python path:
echo $PYTHONPATH -> /home/ruud/Dropbox/ros/catkin_workspace/devel/lib/python2.7/dist-packages:/opt/ros/indigo/lib/python2.7/dist-packages:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/rospkg:/usr/lib/python2.7/dist-packages
The problem looks very similar to http://answers.ros.org/question/44669/fuerte-no-module-named-rospkg/
As far as I see 'rospkg' is not inside /usr/lib/pymodules/python2.7
Help! :) Ruud
Originally posted by Ruud on ROS Answers with karma: 212 on 2015-07-01
I solved the issue by:
$ git clone git://github.com/ros/rospkg.git
$ sudo python setup.py install --user
Apparently rospkg was not installed properly? Still not sure what is the cause though..
Originally posted by Ruud with karma: 212 on 2015-07-01
Comment by gvdhoorn on 2015-07-01:
Hm. If at all possible, I'd avoid using distutils / setuptools to install rospkg. I've seen way too many installs (of ROS) freak out after some time. It's probably better (but more involved) to figure out why the debian pkg doesn't seem to be working for you.
Comment by Ruud on 2015-07-02:
Yes I prefer to find the cause here. Currently it is fixed, but I did not learn a lot from it.. :)
