Hi !
I am currently using ROS Groovy and I recently decided to move from openNI 1.5 to openNI 2.
I tried openni2_tracker and managed to make it work, but I have two problems :
The node needs to find data file ./Nite2/s.dat, so it's not working if you don't run it from a specific directory. Which means you can not put it in a launch file you want to run from anywhere on your system. Is it a normal thing ?
It's not possible to launch the script openni2.launch (with all sensor driver) and openni2_tracker at the same time. It's a problem for me because I would like to run other nodes using the camera data at the same time than openni2_tracker.
Does someone have some information ?
Thanks,
Caroline
Originally posted by CarolineQ on ROS Answers with karma: 395 on 2013-10-09
Comment by sparksmith on 2014-03-06:
hello, sorry for bothering you but how did you run openni2_tracker - because i have a build issue with orocos_kdl ?
Comment by rastaxe on 2014-09-18:
I have the same problem with ROS Hydro. It is not possible to use openni2.launch togheter with openni2_tracker
Comment by manideep on 2016-06-08:
i am using kinect with windows 10, facing same problem.Please can any one solve this error.Thanks in advance
