Hi, This may be trivial, but I have problems understanding how to parse data which comes as sensor_msgs::Image. I used the package openni_camera to get raw frames (camera/depth/image_raw). It says that it contains uint16 depths in mm. I am getting all values between 0 to 255, how do I get uint16?
As I understand, the data field is uint8[] data as shown here http://ros.org/doc/api/sensor_msgs/html/msg/Image.html. The same applies for camera/depth/points which is Pointcloud2 sending Float32. Again how is this represented in a uint8?
Thanks
Originally posted by aswin on ROS Answers with karma: 528 on 2013-06-20
