Hello,
i have a problem with my marker
Marker Picture http://imageshack.us/f/580/markerd.png/
as you can see the last line is very thin and i didn't understand why.
My code is
visualization_msgs::Marker line_strip_obstacles;
line_strip_obstacles.header.frame_id="/map";
line_strip_obstacles.action = visualization_msgs::Marker::ADD;
line_strip_obstacles.lifetime = ros::Duration();
line_strip_obstacles.type = visualization_msgs::Marker::LINE_STRIP;
line_strip_obstacles.scale.x = 0.02;
line_strip_obstacles.scale.y = 0.02;
line_strip_obstacles.scale.z = 1;
line_strip_obstacles.color.r = 1.0;
line_strip_obstacles.color.g = 0;
line_strip_obstacles.color.b = 0;
line_strip_obstacles.color.a = 1.0;
int ctr=0;
for(int j=0;j<number contours();j++){
line_strip_obstacles.points.resize(number contours());
line_strip_obstacles.id = ctr;
for(int i=0 ;number edges;i++){
add point
add first point again to close polygon
maps_marker_pub_.publish(line_strip_obstacles);
ctr++;
the problem is that i have an array of polygon and this is in my opinion the only why i get visualize it.
Anyone has an idea why the last line is so thin?
And one other question. Is it possible that rviz fill an polygon with an colour ? or some work around for it?
thank you for your help
regards Hunk
Originally posted by Hunk on ROS Answers with karma: 222 on 2013-04-10
