Hi All,
I am using ROS Kinetic on Ubuntu 16.04. I am working on a RVIZ Marker program to track "\AMCL_Pose" parameter and visualize in RVIZ. The code I have written is as follows
The following program is used to display the real pose positions taken by the
robot in rviz.
References:
1.https://www.programcreek.com/python/example/88812/visualization_msgs.msg.Marker
import rospy
from visualization_msgs.msg import Marker
from geometry_msgs.msg import PoseWithCovarianceStamped,Point
def callback(data):
    add_point = Point()
    add_point.x = data.pose.pose.position.x
    add_point.y = data.pose.pose.position.y
    add_point.z = 0
    rospy.loginfo('Publishing Marker Point')
    marker.points.append(add_point)
    # Publish the Marker
    pub_point.publish(marker)
    rospy.sleep(5)
marker = Marker()
marker.header.frame_id = "/map"
marker.type = marker.LINE_STRIP
marker.action = marker.ADD
# marker scale
marker.scale.x = 0.03
marker.scale.y = 0.03
marker.scale.z = 0.03
# marker color
marker.color.a = 1.0
marker.color.r = 1.0
marker.color.g = 0.0
marker.color.b = 0.0
# marker orientaiton
marker.pose.orientation.x = 0.0
marker.pose.orientation.y = 0.0
marker.pose.orientation.z = 0.0
marker.pose.orientation.w = 1.0
# marker position
marker.pose.position.x = 0.0
marker.pose.position.y = 0.0
marker.pose.position.z = 0.0
# marker line points
marker.points = []
rospy.loginfo('Marker created')
rospy.init_node('position_tracker')
pub_point = rospy.Publisher('realpoints_marker', Marker, queue_size=1)
print "Publisher created...."
rospy.Subscriber("/amcl_pose",PoseWithCovarianceStamped, callback)
print "Subcriber created...."
rospy.spin()
I get the following result image description
The issue is that the length and orientation of the line are not proper. The robot has moved over 20 meters but in rviz it showing only 5 meters.
How to resolve this issue ?
Originally posted by BV_Pradeep on ROS Answers with karma: 46 on 2019-10-13
Fixed the issue by removing the sleep time in the publisher.
Originally posted by BV_Pradeep with karma: 46 on 2020-01-21
