I want to print VFH signature. Below is my sample code. After VFH signature calculation, how can i print this?
int main (int argc, char** argv)
  pcl::PointCloud<pcl::PointXYZ> cloud;
  //pcl::PointCloud<pcl::PointXYZ>::Ptr cloud (new pcl::PointCloud<pcl::PointXYZ>);
  // Fill in the cloud data
  cloud.width    = 50;
  cloud.height   = 1;
  cloud.is_dense = false;
  cloud.points.resize (cloud.width * cloud.height);
  for (size_t i = 0; i < cloud.points.size (); ++i)
    cloud.points[i].x = 1024 * rand () / (RAND_MAX + 1.0f);
    cloud.points[i].y = 1024 * rand () / (RAND_MAX + 1.0f);
    cloud.points[i].z = 1024 * rand () / (RAND_MAX + 1.0f);
pcl::NormalEstimation<pcl::PointXYZ, pcl::Normal> ne;
          ne.setInputCloud (cloud.makeShared());
          // Create an empty kdtree representation, and pass it to the normal estimation object.
          // Its content will be filled inside the object, based on the given input dataset (as no other search surface is given).
          pcl::search::KdTree<pcl::PointXYZ>::Ptr cloud_normal_tree (new pcl::search::KdTree<pcl::PointXYZ>());
          ne.setSearchMethod (cloud_normal_tree);
          // Output datasets
          pcl::PointCloud<pcl::Normal>::Ptr normals (new pcl::PointCloud<pcl::Normal>);
          // Use all neighbors in a sphere of radius 3cm
          ne.setRadiusSearch (0.03);
          // Compute the features
          ne.compute (*normals);
          // Create the VFH estimation class, and pass the input dataset+normals to it
          pcl::VFHEstimation<pcl::PointXYZ, pcl::Normal, pcl::VFHSignature308> vfh;
          vfh.setInputCloud (cloud.makeShared ());
          vfh.setInputNormals (normals);
          // alternatively, if cloud is of type PointNormal, do vfh.setInputNormals (cloud);
          // Create an empty kdtree representation, and pass it to the FPFH estimation object.
          pcl::search::KdTree<pcl::PointXYZ>::Ptr tree (new pcl::search::KdTree<pcl::PointXYZ> ());
          vfh.setSearchMethod (tree);
          // Output datasets
          pcl::PointCloud<pcl::VFHSignature308>::Ptr vfhs (new pcl::PointCloud<pcl::VFHSignature308> ());
          vfh.compute (*vfhs);
Originally posted by Nihad on ROS Answers with karma: 22 on 2013-04-08
Modified from another question:
pcl::PointCloud<pcl::PointXYZ>::iterator b1;
for (b1 = cloudPCL.points.begin(); b1 < cloudPCL.points.end(); b1++, b2++)
    ROS_INFO_STREAM("x: " << b1->x << ", y: " << b1->y << ", z: " << b1->z);
Originally posted by Adam Allevato with karma: 194 on 2015-05-01
