HI, everyone, I want to install eclipse in GROOVY(following the tutorial:http: // www. ros. org /wiki/IDEs) ,however, In the 2rd step-make eclipse-project, I always get error like:make: *** No rule to make target `eclipse-project'. Stop., I'm sure that I had set my path to the target package, so I have no idea what to do now.
Originally posted by DavidXiong on ROS Answers with karma: 3 on 2013-03-25
Since groovy, with catkin workspaces, you need to call the standard cmake way of building eclipse projects.
I have added an alias in my .bashrc that says the following :
alias catkin_eclipse='catkin_make --force-cmake -G"Eclipse CDT4 - Unix Makefiles"'
But if you don't like aliases, you can just call :
Originally posted by Hansg91 with karma: 1909 on 2013-03-25
Post score: 4
Comment by DavidXiong on 2013-03-27:
@Hansg91,I tried to added an alias in my .bashrc, but it seems no use, and when I use catkin_make --force-cmake -G"Eclipse CDT4 - Unix Makefiles" in the terminal like catkin_make --force-cmake -G"Eclipse CDT4 - Unix Makefiles", I just got The specified source space "/home/tishiba/src" does not exist
Comment by Hansg91 on 2013-04-03:
Are you using a catkin workspace? Then this should work in your root folder of that workspace. If you are using a row workspace then make eclipse-project should still work I believe.
