Hi Martin! (it is funny to greet someone with the same name as yourself xD)
openni_launch has a parameter named device_id that allows you to select the kinect that you want to use:
<!-- device_id can have the following formats:
"B00367707227042B": Use device with given serial number
"#1" : Use first device found
"2@3" : Use device on USB bus 2, address 3
"2@0" : Use first device found on USB bus 2
<arg name="device_id" default="#1" />
so, for instance, you can do:
roslaunch openni_launch openni.launch device_id:=whateveryourdeviceidis
I hope this helps
Originally posted by Martin Peris with karma: 5625 on 2012-10-26
Comment by sai on 2012-10-26:
I am actually having problem in making one device work..Only openni_camera package is working..Can you give me some suggestions on making Kinect work wih ROS Fuerte and ubuntu 12.04
Comment by Martin Peris on 2012-10-27:
Well... unfortunately the OpenNI driver is known to be not very stable on ROS Fuerte + Ubuntu 12.04. This question might shed some light: http://answers.ros.org/question/33622/openni_launch-not-working-in-fuerte-ubuntu-precise-1204/
