Dear all,
i know that some times ago openni_tracker was able to subscribe on the topics published by the openni driver using openni_launch openni.launch However in the corrent version openni_tracker opens the openni driver on it's own. Is it still possible to subscribe on topics published to the network from remote Kinects? Is there an example about how to do this?
kind regards, Tim
UPDATE: the solution was particular easy. Record an oni file with the Kinect camera, than use a xn player to create a depth generator from that oni. finally generate a mockdepthgenerator from that depth generator. after a call of makewritable on the depthmap one can overwrite the depth values with the values coming from the ros topics.
Originally posted by TimB on ROS Answers with karma: 11 on 2013-02-10
On this thread, I explained how to modify the tracker in order to launch it multiple times with multiple kinects.
Maybe it is modifiable in order to connect to remote kinects ? (would be better than saving oni files in my opinion)
Originally posted by Stephane.M with karma: 1304 on 2013-02-17
Comment by TimB on 2013-02-17:
i am not sure about that. It may work. However i have no idea how to instantiate a DepthGenerator or MockDepthGenerator without a physical oder simulated physical device
