Hi,guys,
I need to do some advanced kinect calibration so I need raw data instead of processed depth data. Any one know if /camera/depth/disparity is raw or not? Thank you!
Ranqi
Originally posted by ranqi on ROS Answers with karma: 1 on 2012-08-14
Comment by DiogoCorrea on 2012-12-10:
I have the same question. Do you know the answer now? Thanks.
Are you referring to the disparity image or the depth image published by the driver?
The depth image contains the distance from the camera to the scene along the z-axis (optical axis) of the camera. The ROS openni_camera driver publishes the depth image as a:
  • 16-bit unsigned integer, in millimeters, on camera/depth/image_raw,
  • float, in meters, on camera/depth/image.
(see depth_image_proc)
The ROS driver does not publish the nonlinear, 11-bit raw output of the Kinect.
Originally posted by Ivan Dryanovski with karma: 4954 on 2012-12-10
Comment by DiogoCorrea on 2012-12-16:
I was a little confused and I actually wanted to know if the disparity data published by ROS (/camera/depth/disparity) was the same raw data of libfreenect driver. Apparently are not the same.
Thanks for your answer.
