Hi there!
I'm currently trying to get the CHOMP motion planner working for my robot arm using arm_navigation. So far with no luck, because the planner crashes here at line 795 (@chomp_motion_planner/src/chomp_optimizer.cpp):
00791 const string& jointName = joint_names_[joint];
00792 const KinematicModel::JointModel* jointModel = modelGroup->getJointModel(jointName);
00793 const KinematicModel::RevoluteJointModel* revoluteJoint = dynamic_cast<const KinematicModel::RevoluteJointModel*>(jointModel);
00794
00795 if(revoluteJoint->continuous_)
00796 {
00797 continue;
00798 }
Crashing here makes sense, since my arm contains prismatic joints.
Before I start modifying the code, I would like to ask:
- Is anybody currently using this planner with arm_navigation?
- Did someone successfully apply this planner to arms containing joints other than revolute ones?
- Is there any reason, why the planner is limited to revolute joints? E.g. Is the planner itself not capable of handling joints other than revolute ones?
Thanks!
Originally posted by bit-pirate on ROS Answers with karma: 2062 on 2012-07-10
