I'm fairly new to ROS and especially the arm_navigation stack and was just wondering if there's a simpler method to determine the inverse kinematics of a custom/undefined manipulator than described in the Running arm navigation on non-PR2 arm, which describes altering the pr2_arm_kinematics stack's services and source to suit a custom manipulator. I followed the arm_navigation tutorials and in the inverse kinematics tutorial the source requires services "pr2_right_arm_kinematics/get_ik_solver_info" and "pr2_right_arm_kinematics/get_ik", which I'm sure are only relevant to the pr2 - as is in the description of the pr2_arm_kinematics stack. Likewise with the iROS tutorial and all other's I've found.
Thanks in advance
EDIT: The reason I am not a fan of this method is than I have a 5 DOF robot, not 7. meaning I would have to go through several ~500 line source code files to adapt the code. Or I could go the ineloquent task of added 2 fixed joints and nonexistant links
Originally posted by ocli on ROS Answers with karma: 215 on 2012-05-24
Comment by ocli on 2012-05-24:
I have used the Planning Description Configuration Wizard to attempt to set up the IK solver relevant to my robot, but the tutorial [Inverse kinematics for the PR2 arms] uses pr2 services to determine the IK, which is 7DOF, and cannot suit 5DOF.
Comment by dornhege on 2012-05-24:
The wizard should setup kinematics for your robot, not for the PR2.
Comment by ocli on 2012-05-27:
OK I think I misunderstood the tutorials. It almost works now, just working on a few new problems to do with package dependencies etc. Thanks for the time though
You should definitely check out the Planning Description Configuration Wizard Tutorial.
Originally posted by David Lu with karma: 10932 on 2012-05-24
David Lu's arm_kinematics package will automatically create an IK solver for your non-PR2 arm. You do not really need to worry about the inverse kinematics tutorial you linked to because that is only for PR2 arms. Additionally, I believe the "Planning Description Configuration Wizard" sets up David Lu's IK solver for you.
Originally posted by Dave Coleman with karma: 1396 on 2012-05-24
