Hi,
I followed the instruction on this page http://docs.rosjava.googlecode.com/hg/rosjava_core/html/index.html tried to install and build rosjava. Everything went well until the test step. I executed the command "./gradlew test" and got the following failing message:
Test org.ros.internal.message.MessageSerializationTest FAILED
131 tests completed, 16 failures
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':rosjava:test'.
> There were failing tests. See the report at /home/iratao/my_workspace/rosjava_core/rosjava/build/reports/tests.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Does anyone has an idea about this failure?
Originally posted by ira on ROS Answers with karma: 106 on 2012-05-18
Comment by Markus Eich on 2012-05-21:
same problem here. It seems that the path to /std_msgs/msg/ is not know. At least the report says that 16 messages could not be found.
Comment by damonkohler on 2012-05-21:
Could you add which tests are failing to your post?
