I have troubles installing rosjava_core.
Building > :rosjava_actionlib:compileJava > Resolving dependencies ':rosjava_a:rosjava_actionlib:compileJava
FAILURE: Build failed with an exception.
  • What went wrong: Could not resolve all dependencies for configuration ':rosjava_actionlib:compile'.
Could not find group:ros, module:message.actionlib_msgs, version:0.0.0-SNAPSHOT. Required by: ros.rosjava_core:rosjava_actionlib:0.0.0-SNAPSHOT
Then I tried this tutorial: http://docs.rosjava.googlecode.com/hg/rosjava_core/html/installing.html
  • sudo apt-get install python-setuptools (ran fine)
  • easy_install --prefix ~/.local -U rosinstall
error: can't create or remove files in install directory
The following error occurred while trying to add or remove files in the installation directory:
[Errno 2] No such file or directory: '/home/katrijne/.local/lib/python2.7/site-packages/test-easy-install-4763.write-test'
The installation directory you specified (via --install-dir, --prefix, or the distutils default setting) was:
This directory does not currently exist. Please create it and try again, or choose a different installation directory (using the -d or --install-dir option).
  • export PATH=$PATH:~/.local/bin
  • ... (see the tutorial)
  • easy_install --prefix ~/.local -U pygments (gives the same error as the previous easy_install)
  • roscd rosjava_core
  • ./gradlew install
21:02:09.331 [ERROR] [org.gradle.BuildExceptionReporter] FAILURE: Build failed with an exception. 21:02:09.331 [ERROR] [org.gradle.BuildExceptionReporter] 21:02:09.331 [ERROR] [org.gradle.BuildExceptionReporter] * What went wrong: 21:02:09.332 [ERROR] [org.gradle.BuildExceptionReporter] Execution failed for task ':rosjava_messages:generateSources'. 21:02:09.334 [ERROR] [org.gradle.BuildExceptionReporter] > Command '/usr/lib/jvm/java-6-openjdk/bin/java' finished with (non-zero) exit value 1. 21:02:09.335 [ERROR] [org.gradle.BuildExceptionReporter] 21:02:09.335 [ERROR] [org.gradle.BuildExceptionReporter] * Exception is: 21:02:09.336 [ERROR] [org.gradle.BuildExceptionReporter] org.gradle.api.tasks.TaskExecutionException: Execution failed for task ':rosjava_messages:generateSources'.
Can you help me?
Originally posted by Kat on ROS Answers with karma: 155 on 2012-04-23
The documentation for installing rosjava_core has been recently updated to use pip. Please follow the directions as described there (using rosws and pip).
Originally posted by damonkohler with karma: 3838 on 2012-04-26
