Hi there,
I have a Robot that runs pretty good under ROS. I can teleop it, have a valid URDF-model, I can create maps with the help of the laser scanner. The robot itself is differential driven. It has a rectangular shape with 4 wheels. The motorized wheels are located in the front, where the base_link is located, too. When I follow the tutorials to get the whole navigation stack running. The Path to a navigation goal is calculated and displayed as well. But the robot does not follow the path. It is performing in place rotations instead of forward driving. The cmd_vel-topic says so, too. The angular.z component is at the maximum set in my parameters and the linear x and y component are zero (y should be 0 as it is non holonomic). Is this a known problem? Is it caused by the uncircular shape of the robot? Could anybody help me?
Thanks so far.
Sven
Originally posted by quotschmacher on ROS Answers with karma: 17 on 2012-04-10
