Hello,
I am trying out amcl and move_base on a new home built robot that is similar to the TurtleBot but uses the Serializer microcontroller and Pololu motors and encoders. I also have a Hokuyo laser scanner.
I'm running the odometry loop at 20Hz and the robot can do dead reckoning fairly nicely. Next I created a small map of a couple of rooms using gmapping and that also looks good.
The trouble occurs when I then run amcl and move_base and set a navigation goal in RViz. The robot always gets to the goal fine and follows the planned path fairly well. However, as it is moving it does a kind of pulsed acceleration and deceleration, even when it is moving across a complete clear space. The frequency of the pulsing is about 2 seconds. Is this something that could be tweaked somewhere in the base local planner parameters? I am basically using the TurtleBot parameters for the planner and the cost maps so I won't post them here.
Thanks!
patrick
UPDATE: Jan 1, 2012: It seems I spoke too soon. I am still getting oscillations in cmd_vel as sent to the robot by move_base. I have posted a bag file here demonstrating the phenomenon. I am running move_base with a blank map and fake localization. Then I set a nav_goal about a meter ahead and slightly to the right of the robot in an otherwise clear area. If you rxplot cmd_vel you can see the oscillations in the x component which are very noticeable when watching the robot. For move_base, I am using essentially the identical parameters as in the turtlebot_navigation package.
Can anyone see the cause of this oscillation--perhaps some kind of asynchronization between /odom and /cmd_vel?
Update 2: Here is an rxplot of /cmd_vel/linear/x and /odom/twist/twist/linear/x with the robot up on blocks so the wheels are spinning with no resistance:
rxplot of cmd_vel and odom
Originally posted by Pi Robot on ROS Answers with karma: 4046 on 2011-12-30
Comment by Pi Robot on 2012-01-04:
@Eric Perko - I was not able to create the rxplot on the running robot either--then I discovered that I was not publishing a timestamp on the odom message header. Once I added the timestamp, I was able to get the plot. Unfortunately, adding the timestamp did not fix the oscillation problem.
Comment by Eric Perko on 2012-01-03:
@Pi Robot: Just curious - are you able to create the rxplot while playing back from the bag file you posted or only against the running robot?
Comment by Eric Perko on 2012-01-01:
@Pi Robot: Can you plot rxplot /cmd_vel/linear/x,/odom/twist/twist/linear/x against the live system while you are seeing the oscillations? I can't seem to get it to plot on the same graph on your bag file, and this graph is the one that I think would be most illuminating.
Comment by Pi Robot on 2011-12-31:
Thanks @ahendrix and @Eric Perko. I looked at cmd_vel/linear/x in rxplot and the robot was definitely being sent an oscillating velocity command. Since I wrote the odometry node for the Serializer I figured that was the weakest link. ;-) So I went back to the code and sure enough, I had used Python time() instead of rospy.Time() when computing and publishing odometry messages. Once I fixed that bug, the oscillations disappeared. So I'm guessing I had a small time synchronization error between odom messages and move_base.
Comment by Eric Perko on 2011-12-30:
Have you looked at an rxplot of cmd_vel/linear/x and /odom/twist/twist/linear/x while this pulsing is going on? Do the commands pulse because of weirdness in the reported velocity or do the reported velocities pulse to follow pulsing commands?
From comment above: Thanks @ahendrix and @Eric Perko. I looked at cmd_vel/linear/x in rxplot and the robot was definitely being sent an oscillating velocity command. Since I wrote the odometry node for the Serializer I figured that was the weakest link. ;-) So I went back to the code and sure enough, I had used Python time() instead of rospy.Time() when computing and publishing odometry messages. Once I fixed that bug, the oscillations disappeared. So I'm guessing I had a small time synchronization error between odom messages and move_base
Originally posted by tfoote with karma: 58457 on 2011-12-31
Comment by Pi Robot on 2012-01-01:
@ahendrix and @Eric Perko -- please see Update to my original question.
I've seen problems like this in the past when I've had multiple nodes publishing to the cmd_vel topic; usually move_base and teleop. move_base was sending movement commands, while teleop was sending stop. This usually manifested as stutter rather than pulsing.
An easy check would to be rostopic echo cmd_vel and look at what commands are being sent. You could also use rxgraph to look at individual fields in cmd_vel.
Originally posted by ahendrix with karma: 47576 on 2011-12-30
Comment by chedanix on 2018-02-20:
Thank you sir!!! I included teleop in my launch file and I completely forgot about it. It was secretly sending zero velocity commands the entire time!
