If someone can shoot some wisdom my way I would be much obliged.
I have the gyro installed, showing up on dashboard, all green. When I am driving around performing the mapping, I get the error in terminal from gmapping.
Transform from base_link to odom failed
The below is what I get from dashboard.
Node: /slam_gmapping Time: 1326381589.218725027 Severity: Error Location: /tmp/buildd/ros-electric-slam-gmapping-1.2.4/debian/ros-electric-slam-gmapping/opt/ros/electric/stacks/slam_gmapping/gmapping/src/slam_gmapping.cpp:laserCallback:496 Published Topics: /rosout, /tf, /slam_gmapping/entropy, /map, /map_metadata
Thanks.
Originally posted by osuairt on ROS Answers with karma: 69 on 2012-01-12
Comment by ahendrix on 2012-02-28:
Is this a turtlebot or a turtlebot clone? What is the system load while running gmapping? Does this happen immediately, or only after gmapping has been running for a while?
Comment by osuairt on 2012-02-29:
It is a turtlebot clone. It doesn't happen immediately, say if I spent 15mins driving around a space mapping, I would get the error 4 or 5 times. It can then be seen that the position of the turtlebot jumps in Rviz. I suspect that the inconsistent odom values then play havoc on closing the loop.
From what it seems it looks like a problem with the tf. http://dl.dropbox.com/u/36264864/second.bag
Comment by ahendrix on 2012-02-29:
What are the specs on your computer? What is the system load (uptime, top) while getting this error?
