Hey everyone,
I am facing some trouble while running the navigation stack without a static map on our bot. The problem is, that whenever I am sending a goal to the robot the robot doesn't stop moving. E.g.: I'm sending the bot(base_link) the goal x=1 y=0 z=0 w=0, so he just had to move one meter forward, an he moves and even avoid obstacles, but he doesn't stop moving forward after the goal was arrived. I already checked if the odometry msgs aren't publishing right, but they are.
I think this happens because there isn't a global coordinate frame like /map. Because we aren't using a static map.
Our costmap.yaml file:
global_frame: base_link
robot_base_frame: base_link
update_frequency: 20.0
publish_frequency: 20.0
publish_voxel_map: true
static_map: false
rolling_window: true
width: 6.0
height: 6.0
resolution: 0.025
map_type: voxel
origin_z: 0.0
z_resolution: 1
z_voxels: 32
unknown_threshold: 10
mark_threshold: 0
transform_tolerance: 0.3
obstacle_range: 2.5
max_obstacle_height: 1.0
min_obstacle_height: 0.10
raytrace_range: 3.0
footprint: [[-0.325, -0.325], [-0.325, 0.325], [0.325, 0.325], [0.46, 0.0], [0.325,-0.325]]
footprint_padding: 0.01
inflation_radius: 0.55
cost_scaling_factor: 10.0
lethal_cost_threshold: 100
observation_sources: ....
our localcostmap.yaml:
local_costmap:
update_frequency: 5.0
publish_frequency: 2.0
static_map: false
width: 6.0
height: 6.0
resolution: 0.05
global_costmap:
static_map: false
move_base launch:
<node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
<remap from="/cmd_vel" to="/guardian_controller/command" />
<rosparam file="params_costmap2d.yaml" command="load" ns="global_costmap" />
<rosparam file="params_costmap2d.yaml" command="load" ns="local_costmap" />
<rosparam file="local_costmap_params.yaml" command="load" />
<rosparam file="global_costmap_params.yaml" command="load" />
</node>
Which global_frame should I use, if I'm not using a map?
Thank you in advance
Originally posted by jarjarbings on ROS Answers with karma: 23 on 2011-09-12
