Hi,
I think that ROS can't access my Create... Is not possible see informations about the robot in turtlebot_dashboard, like battery and sensors status, but is possible to see netbook battery status, then I can conclude that the connection Workstation-netbook is ok, the problem could be between the netbook and Create. The status of all sensors in turtlebot_dashboard is Stale, except the netbook battery.
I'm using a serial-usb converter, because my Create uses a serial-serial cable. Could it be the problem?
Using "dmesg" and "lsusb" commands, I can see that my converter is properly connected at ttyUSB0. And I've tried to change the default_port in turtlebot_node.py to another USB and serial ports, but the error continues.
Thanks in advance, Lucas
Originally posted by lucascoelho on ROS Answers with karma: 497 on 2011-09-12
