On a fresh checkout of gps_common , my utm_odometry_node fails to build, citing the error:
Linking CXX executable ../bin/utm_odometry_node CMakeFiles/utm_odometry_node.dir/src/utm_odometry_node.o: In function `ros::serialization::Stream::advance(unsigned int)':
/opt/ros/diamondback/ros/core/roslib/include/ros/serialization.h:675: undefined reference to `ros::serialization::throwStreamOverrun()'
CMakeFiles/utm_odometry_node.dir/src/utm_odometry_node.o:/opt/ros/diamondback/ros/core/roslib/include/ros/serialization.h:675: more undefined references to `ros::serialization::throwStreamOverrun()' follow collect2: ld returned 1 exit status
The issue seems to be that throwStreamOverrun() alone is not defined in serialization.h; it's defined in serialization.cpp. I'm running ROS diamondback on Lucid.
Is there a simple workaround?
Originally posted by PKG on ROS Answers with karma: 365 on 2011-08-22
There was an unmet dependency of roscpp_serialization in this package.
Originally posted by PKG with karma: 365 on 2011-08-27
I had the same problem, one of my friends told me I was missing some linker dependencies to ros::serialization::throwStreamOverrun().
And also that I needed to add the package that contains ros::serialization to the build_dependencies and the run_dependencies in the package.xml and also to the CMakeLists.txt.
In the CMake-file the build_dependencies are in the line that starts with find_package(catkin REQUIRED COMPONENTS and the run_dependencies usually are in the catkin_package( ... block. Also, in the line target_link_libraries(your_executable ${catkin_LIBRARIES}) that belongs to your executable you might need to add the ${catkin_LIBRARIES} if it is not already there.
For me that worked and hope for you also.
Originally posted by lizyazpin with karma: 1 on 2013-11-10
