I am using ROS on Ubuntu 10.04, and the command "roslaunch openni_camera openni_node.launch" has suddenly started to give me an error. Is there a way to fix this?
robot@peoplebot2:~$ roslaunch openni_camera openni_node.launch
... logging to /home/robot/.ros/log/7354f21c-a317-11e0-8aa3-a088b4402bbc/roslaunch-peoplebot2-1665.log
Press Ctrl-C to interrupt
started roslaunch server http://peoplebot2:50030/
SUMMARY
PARAMETERS
 * /rosdistro
 * /openni_node1/use_indices
 * /openni_node1/depth_registration
 * /openni_node1/image_time_offset
 * /openni_node1/depth_frame_id
 * /openni_node1/depth_mode
 * /openni_node1/debayering
 * /rosversion
 * /openni_node1/projector_depth_baseline
 * /openni_node1/rgb_frame_id
 * /openni_node1/depth_rgb_translation
 * /openni_node1/depth_time_offset
 * /openni_node1/image_mode
 * /openni_node1/shift_offset
 * /openni_node1/device_id
 * /openni_node1/depth_rgb_rotation
NODES
    openni_node1 (openni_camera/openni_node)
    kinect_base_link (tf/static_transform_publisher)
    kinect_base_link1 (tf/static_transform_publisher)
    kinect_base_link2 (tf/static_transform_publisher)
    kinect_base_link3 (tf/static_transform_publisher)
auto-starting new master
process[master]: started with pid [1679]
setting /run_id to 7354f21c-a317-11e0-8aa3-a088b4402bbc
process[rosout-1]: started with pid [1692]
started core service [/rosout]
process[openni_node1-2]: started with pid [1695]
process[kinect_base_link-3]: started with pid [1696]
process[kinect_base_link1-4]: started with pid [1697]
process[kinect_base_link2-5]: started with pid [1698]
process[kinect_base_link3-6]: started with pid [1699]
/opt/ros/diamondback/stacks/openni_kinect/openni_camera/bin/openni_node: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.12' not found (required by /usr/lib/libOpenNI.so)
[openni_node1-2] process has died [pid 1695, exit code 1].
log files: /home/robot/.ros/log/7354f21c-a317-11e0-8aa3-a088b4402bbc/openni_node1-2*.log
I have followed dornhege's advice from the comments in the answer by fergs. When I only use the command "roslaunch openni_camera openni_node.launch", it runs correctly. However, when I try to use other packages that require the openni_camera, such as rviz or openni_tracker, this new error occurs. Does anyone have an idea for fixing it?
Originally posted by qdocehf on ROS Answers with karma: 208 on 2011-06-30
no activity > 1 month, closing
Originally posted by kwc with karma: 12244 on 2011-09-02
Lucid (10.04) uses GLIBC 2.11, so lucid packages should not be linked against 2.12. Are you sure that you selected the right repository when you did step 1.2 of installation? I would guess that you might have typed "maverick" instead of "lucid" thus installing packages that use GLIBC 2.12.
Originally posted by fergs with karma: 13902 on 2011-07-06
Comment by Asomerville on 2011-07-14:
@qdocehf I would suggest removing the second question and making a separate posting for it.
Comment by qdocehf on 2011-07-07:
Do you have any ideas for fixing this new error? I have edited my question to include the new problem.
Comment by dornhege on 2011-07-07:
Can your try running apt-get update, apt-get upgrade and eventually apt-get --reinstall install openni-dev. That should get you up to date to the current lucid packages.
Comment by qdocehf on 2011-07-06:
ros-diamondback-openni-kinect: Installed: 0.2.1-s1306611764~lucid Candidate: 0.2.1-s1306611764~lucid Version table: *** 0.2.1-s1306611764~lucid 0 500 http://packages.ros.org/ros/ubuntu/ lucid/main Packages 100 /var/lib/dpkg/status
Comment by dornhege on 2011-07-06:
To verify, what does: apt-cache policy ros-diamondback-openni-kinect give you?
Yes, I definitely used the lucid installation. I even tried uninstalling and reinstalling it, so I don't think that could be the problem.
