Hello!
I checked out today the gazebo package, from simulator_gazebo: https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/trunk and it does not compile! I get a lot of errors, concerning the urdf2gazebo. Here is the beginning of the error messages:
/opt/ros/diamondback/stacks/simulator_gazebo/gazebo/src/urdf2gazebo.cpp:755: error: ‘class urdf::Link’ has no member named ‘addCollision’
/opt/ros/diamondback/stacks/simulator_gazebo/gazebo/src/urdf2gazebo.cpp: In member function ‘void
urdf2gazebo::URDF2Gazebo::printCollisionGroups(boost::shared_ptr<urdf::Link>)’:
/opt/ros/diamondback/stacks/simulator_gazebo/gazebo/src/urdf2gazebo.cpp:801: error: ‘class urdf::Link’ has no member named ‘collision_groups’
I reinstalled my ROS-System today, from: sudo apt-get install ros-diamondback-desktop-full
Can anyone tell me what I am missing? thanks
Originally posted by Kike on ROS Answers with karma: 41 on 2011-06-03
Comment by Asomerville on 2011-06-05:
Actually the "edit" link below your posts allows you to edit it after the fact.
Comment by Kike on 2011-06-03:
of course, sorry! i will keep it in mind for the next time!
Comment by Asomerville on 2011-06-03:
If you don't mind, please put the error message in "code" formatting (the button is marked "101010"). It's much easier to read that way. (might want to drop the ! as well)
