I have downloaded the code using
  • source /opt/ros/diamondback/setup.bash
  • sudo apt-get install python-setuptools
  • sudo easy_install rosinstall
  • mkdir -p ~/ros-gazebo/workspace
  • rosinstall ~/ros-gazebo /opt/ros/diamondback ~/ros-gazebo/workspace
  • cd ~/ros-gazebo/workspace
  • svn co https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/tags/diamondback simulator_gazebo
  • source ~/ros-gazebo/setup.bash
  • rosmake gazebo
The same procedure is also described in this post.
Now when i use 'roslaunch gazebo_worlds wg_world.launch' it gives me the following error.
/home/student/ros-gazebo/workspace/simulator_gazebo/gazebo/build/gazebo/build/server/gazebo: error while loading shared libraries: libparallel_quickstep.so: cannot open shared object file: No such file or directory
Any idea how to fix this problem??
PS: i have one instalation in /opt/ros. and this installation is in /home/ros-gazebo/workspace/simulator_gazebo/...
Originally posted by SAK on ROS Answers with karma: 94 on 2011-08-04
Comment by SAK on 2011-08-07:
No i am writing the correct command, now i am making with rosmake gazebo_worlds and see what is the outcome..
Comment by hsu on 2011-08-07:
by the way, might be a typo, 'roslaunch gazebo_world wg_world.launch' should be 'roslaunch gazebo_worlds wg_world.launch'?
Comment by Dan Lazewatsky on 2011-08-05:
Is parallel_quickstep installed and on your ROS_PACKAGE_PATH?
Comment by Lorenz on 2011-08-05:
For me, these steps were working. I just tried. Did you do anything else? Is your gazebo checkout maby dirty? (roscd gazebo; svn st, then check if something is marked with M for modified). If so, make a backup, delete the directory ~/ros-gazebo and try again.
Did rosmake gazebo return any errors? If the build was successful, when you roslaunch any gazebo world launch files, it should have invoked the following binary:
/home/student/ros-gazebo/workspace/simulator_gazebo/gazebo/gazebo/bin/gazebo
not
This seems to suggest the build did not complete. Can you verify and check the console output of the rosmake command?
The version of the gazebo binary referenced in your original question will not have the correct link paths setup, hence you see the error with not finding the libparallel_quickstep.so library.
Originally posted by hsu with karma: 5780 on 2011-08-07
Comment by hsu on 2011-08-08:
removing the file called 'installed' simply forces make to do a recompile + install in case the previous installs left system in a bad state.
after applying the steps it gives no error and the system now works... thanks for the help.. but i want to know that rm installed removes the previous installation or what it is doing.
Please make from within ' ~/ros-gazebo/workspace/simulator_gazebo/gazebo/' to make sure the correct gazebo binary is installed. Performing make in ' ~/ros-gazebo/workspace/simulator_gazebo/gazebo/build/gazebo/build' is not sufficient. What happens when you do, 'roscd gazebo; rm installed; make;'?
/home/student/ros-gazebo/workspace/simulator_gazebo/gazebo/build/gazebo/server/sensors/ir is the full path to the IRSensor.cc, or from the website https://kforge.ros.org/gazebo/trac/browser/server#sensors/ir is the same. btw i didn't patch anything yet. i want to patch the IRSensor.cc
What happens when you do, 'roscd gazebo; rm installed; make;'? Also, what is full path of the file (IRSensor.cc) that you patched? Lastly, can you post the patch? Thanks.
After rosmake gazebo_worlds,, the error disappeared but when i try to 'make' ~/ros-gazebo/workspace/simulator_gazebo/gazebo/build/gazebo/build,,, here ,, the error comes again. As i want to change the file IRSensor.cc, because the GetIRCount function in this file is not working. so i did make here.
When i try to roslaunch with my original path /opt/ros/diamondback.... it works but when i try with path ~/ros-gazebo/workspace/diamondback..:$ROS_PACKAGE_PATH then the roslaunch gives me an error
