Hi everyone,
after an upgrade of my Fedora system (now version 14) and a reinstall of ROS I tryed to start roscore but I got following message all the time:
[eos@poseidonius Documents]$ roscore
... logging to /home/eos/.ros/log/41d3b050-4838-11e0-95f3-0024d71f2bbc/roslaunch-poseidonius-13240.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
Unable to contact my own XML-RPC server, this is a highly unusual error and should be reported immediately. My URI is [http://poseidonius:45166/]
Just some variable checks according to other questions found in the internet:
echo $ROS_HOST (empty but set to) poseidonius
echo $ROS_IP (empty but set correct) 192.168.178.31
echo $ROS_MASTER_URI (http://localhost:11311 set to) http://poseidonius:11311
What I have to do?
Originally posted by Poseidonius on ROS Answers with karma: 427 on 2011-03-06
Comment by Poseidonius on 2011-03-06:
Hi Eric, yes, you are right. The values in branches are the ROS "default" values on my computer. After some websites I changed them to the second ones ...
Comment by Eric Perko on 2011-03-06:
With your "echo $ROS_*", what exactly do you mean by "empty but set..."? Do you set them before running roscore? Do you mean they are empty and the values listed are what you expect? The values listed are the values for your computer?
