I performed a update of my package based ROS installation yesterday (12.04, groovy, AMD64) and tried to start a roscore today, which results in the following output:
kohlbrecher@opstation:~$ roscore WARNING: unable to configure logging. No log files will be generated Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is rosmaster.rosmaster_main() File "/opt/ros/groovy/lib/python2.7/dist-packages/rosmaster/main.py", line 73, in rosmaster_main configure_logging() File "/opt/ros/groovy/lib/python2.7/dist-packages/rosmaster/main.py", line 57, in configure_logging _log_filename = rosgraph.roslogging.configure_logging('rosmaster', logging.DEBUG, filename=filename) File "/opt/ros/groovy/lib/python2.7/dist-packages/rosgraph/roslogging.py", line 105, in configure_logging logging.config.fileConfig(config_file, disable_existing_loggers=False) File "/usr/lib/python2.7/logging/config.py", line 78, in fileConfig handlers = _install_handlers(cp, formatters) File "/usr/lib/python2.7/logging/config.py", line 153, in _install_handlers klass = _resolve(klass) File "/usr/lib/python2.7/logging/config.py", line 88, in _resolve found = __import__(used) File "/opt/ros/groovy/lib/python2.7/dist-packages/rospy/__init__.py", line 49, in from .client import spin, myargv, init_node, \ File "/opt/ros/groovy/lib/python2.7/dist-packages/rospy/client.py", line 59, in import rospy.impl.init File "/opt/ros/groovy/lib/python2.7/dist-packages/rospy/impl/init.py", line 107, in class RosStreamHandler(rosgraph.roslogging.RosStreamHandler): AttributeError: 'module' object has no attribute 'RosStreamHandler' [master] process has died [pid 2686, exit code 1, cmd rosmaster --core -p 11311 __log:=/home/kohlbrecher/.ros/log/e4297ce0-9d04-11e2-8192-9439e59a9133/master.log]. log file: /home/kohlbrecher/.ros/log/e4297ce0-9d04-11e2-8192-9439e59a9133/master*.log ERROR: could not contact master [http://opstation:11311/] [master] killing on exit
I also have fuerte installed and fuerte's roscore starts up fine.
I'm not aware of any changes on my part that could be responsible. OTOH I'd expect ROS Answers to be full of complaints if this happened to everyone. Any hints on how to solve the problems are appreciated.
/edit: Errors about 'module' having no 'RosStreamHandler' attribute also appear in other python code besides roscore (for the moment using the fuerte master with groovy nodes)
Originally posted by Stefan Kohlbrecher on ROS Answers with karma: 24361 on 2013-04-03
Comment by dornhege on 2013-04-04:
I'm running on Natty/11.10, AMD64 and just updated groovy. roscore starts fine. It's not exactly the same, so it must be something specific.
Comment by inflo on 2013-04-04:
hi, i updated today fuerte and cant start roscore. It fails with:
