There is no "full" installation of ROS as ROS supports many different types of robots. It sounds like you installed the "pr2all" version of ROS C Turtle, which comes with many PR2-specific capabilities.
In Diamondback, we have tried to streamline the stacks that you get when you install. The packages themselves are also about half their size in C Turtle.
The following are the sizes of some recommended installs:
442MB ros-diamondback-desktop
1.1GB ros-diamondback-desktop-full
NOTE: you have to install drivers separately.
If you need to use arm navigation, which is still experimental, it will add about 500MB to your installation.
Originally posted by kwc with karma: 12244 on 2011-03-01
Post score: 4
Comment by Homer Manalo on 2011-03-01:
Looks like a nodev option is fine. roscore is running fine and I have launched a couple of nodes.
What about mounting /opt to another partition? Is it safe (not running any ros commands)? I'm also not sure what my options should be on the fstab.
Comment by joq on 2011-03-01:
Yes, those are binary packages.
What I mean by "full" installation is really the desktop-full install, and btw I installed the cturtle-base. Is that 1.1GB already built?
Comment by kwc on 2011-03-01:
If I interpret apt-get correctly, the download size is about 25%
Comment by Eric Perko on 2011-03-01:
How large is the download size compared to the unpacked size? Once in a while I run into problems where I cannot even download all of the updates at once because I have so little free space on the robot.
